Setting for Hiding exentions, Graph View
At minimum I would like to see the similar hiding of extensions in graph view for .bases and .canvas as there is for .md. I wouldn’t mind a toggle for other file extensions being hidden
  1. Change the default node shape that is used, circular or square for example to denote different note types. with option for all uniform.
1.5. Known file extensions like media, could be embedded in the graph, thumbnail for photos, a play pause speaker icon for audio. miniplayer that plays video while the graph is fixed(to start with)…
  1. A toggle slider for hiding the extensions of non-obisian(.md .canvas . base) files…
Possible Related feature requests (SEMI-RELATED) while you consider refactoring
.hotlink… /t/global-setting-to-save-new-markdown-files-with-hide-extension-true/98944
