  • Operating system: macOS 11.4
  • Obsidian version: 0.12.8
Syncing using iCloud
I don’t understand.
If I’m getting this one right, I have the same issue. Folder where new attachments should be stored has been defined, and yet new attachments end up on the root.
I can’t reproduce. Please, post a screen recording.
My apologies but I don’t know what happened to the explanation I typed up of the issue I am experiencing because it looks like most of what I typed is not there.
When I open preferences in Obsidian I am changing the setting in “Files & Links” about where to save attachments in notes. When I change it to “In subfolder under current folder” but that change does not appear to be saved.
The screen recording of what I am doing can be found here:
thank you
You didn’t specify any subfolder. So what do you expect?
I did not see that part of the form appear because it is off of the screen. Thanks for pointing that out (kind of).
