I have a Go code block and go uses the <- sequence in code, which is translated to a left arrow. And this left arrow somehow seems to change the coloring of the text following it to yellow.
I don’t have any idea why this happens, nor how to avoid this. Does anybody have a good tip for me?
I believe this are the ligatures of your font. Have you tried with a different theme or font?
I’m not sure why this would change the syntax highlighting after it though.
Here is another example:
The remove the < char fixes the coloring. It looks like the < char is interpreted as some markup which doesn’t make sense in a code block.
How to change the font? I don’t find an option for this?
