Separate the debug start up time so it is per-vault and not a global setting
I have my main vault and a secondary vault I use for developing plugins. The plugin development vault has the one plugin I am updating + the hot reload plugin. That’s it. No custom themes, nothing.
When I enable the “debug startup time” in my development vault, it is also enabled in my main vault. When I disable it in my main vault, it is also disabled in my development vault.
Add this to the .obsidian folder so that this can be a per-vault setting instead of a global setting.
Just keep it enabled when I am developing and disable it before I finish developing.
