In the spirit of Semantic Versioning, I come up with an idea to semantic versioning my vault. Here is the idea:
Given a version number MAJOR.MINOR.PATCH, increment the:
- MAJOR version when root folder has significant changes
- MINOR version when 1st-level folders has significant changes
- PATCH version when 2st-level folders has significant changes
What is significance is up to you. For me, it may be adding or removing a file or folder. Renaming without changing the idea much may be denoted with a letter after (i.e. 3
→3a
→3b
). If your root folder’s structure is already stable before you apply the versioning, you foresee that it will be stable in a far future, then you can skip the MAJOR version if you want.
This idea can be generalize to any hierarchical structure, not just limited to folder structure. For example, a hierarchical graph.
What do you think about this idea?
FYI, in Git you can add tags with:
git tag -a v1.3 -m "tag label here"
If you are new with Git, you can start with Learn Git Branching and Picturing Git: Conceptions and Misconceptions - BiTE Interactive. It really helps me.
