Juggl (Out now! 1.0.1): A completely interactive, stylable and expandable graph view plugin!
Juggl is a completely interactive, stylable and expandable graph view plugin for Obsidian.
It is designed as an advanced ‘local’ graph view called the ‘workspace’, where you can juggle all your thoughts with ease.
With Juggl, you can navigate Obsidian through a beautiful graph! For example, you can select what parts of the graph to expand, to make sure there is never too much information on the screen.
Juggl is also super-customizable! For starters, it has a useful styling pane nodes colors, shapes, sizes, and icons which helps you get an immediate overview over what the content of each node is.
Features
Juggl has many features unique to its graph view compared to the Obsidian graph view:
  • Complete control over the style of your graph using CSS, YAML and the Style Pane .
    • Include images!
  • A Workspace mode that lets you build your graph with all nodes that are relevant to your current project
    • Selectively browse and hide nodes, and pin their location so you never lose them
    • Write new ideas and see your graph evolve
    • Save your graph and continue working on it later
  • 4 different layouts to get unique insights
  • A code fence that displays the graph within Obsidian notes
  • Link type support to label edges
  • No need to install Python or Neo4j, unlike Neo4j Graph View
  • Extendable through other plugins
  • Works on mobile!
Getting started
You can open Juggl from the ‘more options’ menu on files:
You can interact with the graph with many of the same options as in Obsidian. For further documentation, check out juggl.io, where you can find information on for example styling or the syntax of the code fence.
You can also open the help vault with this button in Juggl:
Hi Emile!.. this is amazing!, well, the idea. I still cannot make it work. I’ve tried two graphs, but it seems my computer doesn’t want to load them. Do you have an example graph to look at?
Thank you Cristian!
You can download the export of the Obsidian help graph here: https://www.dropbox.com/s/5txmnik2v0g393i/out.cypher?dl=0
It seems to import well, but Neo4j Bloom seems to only show 5 nodes for me, for some reason? It works properly in Neo4j desktop though.
Can you explain what problem you’re running into? Or at what step?
I cannot see any imported nodes in my Neo4j Instance… I’ll look into it later today :slight_smile:
Hello, i have tried to follow the instructions, i installed Python 3.9.1 (restarted the computer after) and also installed Neo4j.
But i fail already at point 2 (installing smdc command): i get the following output in python:
Python 3.9.1 (tags/v3.9.1:1e5d33e, Dec 7 2020, 17:08:21) [MSC v.1927 64 bit (AMD64)] on win32
Type “help”, “copyright”, “credits” or “license” for more information.
pip install semantic-markdown-converter
File “”, line 1
SyntaxError: invalid syntax
What i am doing wrong?
EDIT: solved it already - my bad - it was supposed to be a console command =(
Glad to hear you solved it :slight_smile: Indeed, it’s a console command!
Second issue arised:
after installing, i used: smdc --input “folder with notes”
i got the following error:
import yaml
ModuleNotFoundError: No module named ‘yaml’
Do i need to install another package first?
EDIT: solved it… for anyone running into the same issues: i needed to install some packages first. For me it was : "pip install pyyaml AND pip install tqdm
For this one, you can install the yaml library with:
pip install pyyaml
Finished the installation, created the out.cypher file (its populated with all entrys from my zettelkasten) - after i called apoc.cypher.runFile it finishes very fast and no nodes are created. In Bloom i therefor cant see anything.
What might be missing? The out.cypher file is in the import folder (and its not empty)
Ahh… I hoped to automatically do this, but looks like that failed. I fixed it now, I think. Glad you figured it out!
Hmm, what did it say at the bottom of the ‘card’ of the result? Where it says “Started streaming 256 records after 2 ms and completed after 4992 ms.”? It could be there is some particularity in your data I haven’t accounted for.
Also, I noticed Neo4j Bloom is sometimes not displaying some data that is in the dataset. To ensure there really isn’t anything, run MATCH (n) RETURN count(n) in the browser.
(no changes, no records)
Completed after 545 ms
If i switch to code view:
Neo4j/4.1.3
Server address localhost:7687
Query CALL apoc.cypher.runFile(‘out.cypher’)
Summary
“query”: {
“text”: “CALL apoc.cypher.runFile(‘out.cypher’)”,
“parameters”: {}
“queryType”: “rw”,
“counters”: {
“_stats”: {
“nodesCreated”: 0,
“nodesDeleted”: 0,
“relationshipsCreated”: 0,
“relationshipsDeleted”: 0,
“propertiesSet”: 0,
“labelsAdded”: 0,
“labelsRemoved”: 0,
“indexesAdded”: 0,
“indexesRemoved”: 0,
“constraintsAdded”: 0,
“constraintsRemoved”: 0
“_systemUpdates”: 0
“updateStatistics”: {
“_stats”: {
“nodesCreated”: 0,
“nodesDeleted”: 0,
“propertiesSet”: 0,
“labelsAdded”: 0,
“labelsRemoved”: 0,
“indexesAdded”: 0,
“_systemUpdates”: 0
“plan”: false,
“profile”: false,
“notifications”: ,
“server”: {
“address”: “localhost:7687”,
“version”: “Neo4j/4.1.3”
“resultConsumedAfter”: {
“low”: 539,
“high”: 0
“resultAvailableAfter”: {
“low”: 6,
“high”: 0
“database”: {
“name”: “neo4j”
Response
If i check with the command you provided it says Count: 0
The file is there, if i delete it (or rename it) it throws an error instead of this.
Okay, that seems to be the same problem as in https://github.com/HEmile/semantic-markdown-converter/issues/1 . I’ve just pushed a fix for this (just run pip install --upgrade semantic-markdown-converter, then try again).
Anyways, I’ve been thinking about how to make this easier to use. Luckily, it’s possible to upload data to neo4j directly from Python! So I’ll do this for the next version.
Then I’ll look into making a very simple Obsidian plugin that automates calling the command.
When I run to smdc, this error occurs
UnicodeDecodeError: ‘gbk’ codec can’t decode byte 0x80 in position 20: illegal multibyte sequence
Looks like this might happen because the code wasn’t reading/writing in utf-8 and you used special characters. Can you do pip install --upgrade semantic-markdown-converter and try again?
Version 0.2.0 is now out! Install with pip install --upgrade semantic-markdown-converter.
This version makes it easier to get your data into neo4j. Now all you have to do is start your database and run smdc --input "folder with notes" --password "neo4j database password".
Version 0.3.0 is now out! Again, upgrade with pip install --upgrade semantic-markdown-converter
This version automatically streams all updates in your Obsidian vault to Neo4j, meaning you only have to turn it on once and have all changes automatically reflected in Neo4j.
I also fixed some missing data issues.
@Emile Thank you for offer to support other syntax, here is my use case, feel free to improve the syntax if needed. I tried to come up with natural, flexible enough to describe any bill of material which will for example allow to transitively/recursively sum up quantities of materials needed for given catering plan.
Markdown nested list, similar to Yaml but using structured text in place of leaf string as a way to add properties in “natural language way” and include wiki or markdown links.
# food 1
some
- irrelevant text
- contains:
	- 1 kg of [[food 2]]
	- [[food 3]]
	- approximately 3 pieces of [[food 4]]
	- 1 piece of [[food 5]] # optionally 2 pieces
	- previously also:
		- 1 piece of [[food 6]]
- another irrelevant
	- text
In a graph, I would like to get relations where
({ID: 'food 1'})-[:contains {quantity: 1, unit: kg}]->({ID: 'food 2'})
({ID: 'food 1'})-[:contains {quantity: "", unit: ""}]->({ID: 'food 3'})
({ID: 'food 1'})-[:contains {quantity: 3, unit: piece}]->({ID: 'food 4'})
({ID: 'food 1'})-[:contains {quantity: 1, unit: piece}]->({ID: 'food 5'})
Sorry if my formulation in Cypher is incorrect.
Processing:
  • list of relations starts by non-indented line in form
    - <linktype>:
  • indented list item expected to be in form - text <amount> <unit> <preposition> <[[linktosubject|text]]> # another text which might contain links
  • treat filename of the file as a “subject” of relations
  • ignore list items that do not contain link. (maybe treat dead links with missing target file as valid.)
  • ignore comment after "# " till end of line (requiring comment separator means that this can be extension of your original proposed syntax with more links (objects) on one line separated by comma, when colon after link type is optional or signifies initiation of hyphenated multi-line list. )
  • ignore optional prepositions before link, e.g. " of "
  • ignore link text after pipe
  • for start, ignore text before the decimal number or link
  • store decimal number in property “quantity” of the edge/link/relation
  • store string in property “unit” of the edge/link/relation
  • allow specification of equivalent units like piece, pieces, ks (although this could be treated by user later in graph database, but for real time interaction between markdown and graph, treating this automatically like aliases would be nice.)
  • similarly aliases for link-types. contains, obsahuje Could be specified as equivalent.
aliases would allow to adjust to any language.
Czech version:
# potravina 1
some
irrelevant text
- obsahuje:
	- 1 kg [[potravina 2|potraviny 2]]
	- [[potravina 3]]
	- asi 2 ks [[potravina 4]]
	- 1 ks [[potravina 5]] # mohou být i 2 kusy.
	- dříve také:
		- 1 ks [[potravina 6]]
Hi, that certainly looks like a useful thing to have. Adding properties in a ‘natural language’ way would be very useful, but it sounds hard to interpret. In your example, in particular, how would the interpreter know how to process it as - text <amount> <unit> <preposition> <[[linktosubject|text]]> # another text which might contain links?
Aspen offers a nice syntax to maybe allow defining such constructs. And your example reminds me a bit of Semantic Authoring Markup: https://mbakeranalecta.github.io/sam/quickstart.html Although this also seems a bit hard to interpret correctly
I will try to describe how I would approach it with my limited skills. (For example I am using AutoHotkey in Obsidian-edit-mode to open markdown-style-link which surrounds or precedes caret (cursor). When link target does not exist, then It gets created and prefilled with header based on info from the parsed link.)
Assume I have relevant indented lines available and processing them one by one, My approach in following:
  • Have dictionary of prepositions to ignore {“of”, …}.
  • Have dictionary of (measurement) units and it’s aliases {kg: kg, piece: piece, pieces: piece, ks: piece}.
  • L := current line to process
  • L := L without part starting by "# " or “//”
  • While there is link in L:
  • Find first link in the line and store it as object of relation (you have this already implemented likely)
  • B := part of L before link
  • A := [] # empty array
  • Parse part before found link by space character into array A of “word” strings
  • If last word from A matches item from dictionary of prepositions, pop it out from array A.
  • If last word starts with digits followed by letters, then split it into two ( “99units” → “99”, “units” ).
  • Now If last word matches item from dictionary of units (with aliases), add corresponding unit to property of relation and pop it out from array A.
  • If last word from A is number, then add it to property “quentity” of the relation
  • If relation does not have defined quantity, then set quantity = 1
  • // ignore rest of array A
  • L := part of L after the link // this allows to process list separated by commas
  • } // end of While there is link in L
I don’t know how doable this would be, but this would be such an amazing thing to be made into a plugin!
