You can’t escape the second backtick of inline code. Instead, it assumes it’s the closing backtick. The other ones can be escaped. (Doesn’t work on discourse either)
For example, the text in the image below should be displayed as -\`-\`-.
Not sure if this is an issue with an older version. But it seems to be working in the current version of Obsidian 0.12.12.
You should use double backticks to escape a single backtick like this: `` -\`-\`- ``
it will get rendered like this: -\`-\`-
Reference: How do I escape a backtick ` within in-line code in Markdown? - Meta Stack Exchange
thanks
