- Create a new note
- Add the following Markdown:
Test test
# Some heading
Keyword
# Another heading
Test
- Collapse
Some heading
- Search
keyword
- The heading the search result is under stays collapsed, and you can’t find the search result.
The heading should expand and the search term should be highlighted and visible in the note.
It’s invisible and it’s unclear that the search was actually successful.
- Operating system: Arch Linux
- Obsidian version: v0.11.5
