I would like a to use the search pane to only search the active note. This could be an operator like active-note: or current-note: or a shortcut to insert the filename.
There are ways around this, but they are not ideal:
Search in current file doesn’t offer the same features as global search, and I would like to see the results before I start clicking through them.
- I could use the
file: operator, but then I have to select the filename, copy, select the search pane, and paste. If there was a shortcut to copy the filename, then this might be easier. https://forum.obsidian.md/t/hotkey-that-copies-current-notes-filename/4959
A use case is that I have a long meeting note with tags in places where I want to follow-up.
