- Create note with folded callout block.
>[!example] Parent block
> It doesn't have to be callout, simple `> `, will behave identical`
>>[!bug]- Folded block
>>Search this text
>> [!note]- Other folded block
>>Lorem ipsum dolor sit amet
2a. ctr
+ f
and search Search this text
2b. Search "Search this text"
using search pane when test file is closed.
- Block containing searched text will be unfolded and only searched text will be highlighted.
- If block containing searched text is nested inside other folded block - it also should be unfolded.
2a)
- if note is in edit mode it will be fine.
- if note is in reading mode and callout is expanded it will be fine.
- if note is in reading mode and callout is folded search UI will not change colour to red, but it will not highlight search result.
2b)
- if Obsidian is set to open new files in edit mode - it will be fine.
- if Obsidian is set to open new files in reading mode search will highlight whole block - this is problematic for long notes inside callouts and nested callout blocks(it will highlight whole
Parent block
not onlyFolded block
- Operating system: Linux Manjaro
- Debug info:
Obsidian version: v0.15.9
Installer version: v0.15.9
Operating system: #1 SMP PREEMPT Thu Aug 11 13:14:01 UTC 2022 5.10.136-1-MANJARO
Legacy editor: off
Current behaviour makes notes with large number of folded callouts block (especially nested ones) unsearchable.
