Search for wikilinks starting with [[ conflicts with properties
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I am using almost ever wikilinks instead of tags.
I used to search for this links via global search: [[wikilinks
It has worked well, until the update with the “search for properties” in the last year.
Since then, the search for [[ conflicts with search for properties.
I am still able to search for exact matching wikilinks by search for “[[wikilinks”.
But have to use workarounds to get results for links with the same starting phrase.
It was very useful to me, that I was able to search for: [[wiki
and all results even for [[wikilinks showed up, but not “normal” words in text beginning with wiki.
I am asking you, if you could change the symbol for searching for properties.
So no more using “[” but something else instead maybe “%%” or “<<” or likes.
Or get access again to search for wikilinks by typing: [[wikilink
