I’ve tried find out how to do it. Just using two tags in te search field don’t work. I’m also not trying to find two tags in the same block, but in the same document, so block:(#tag1#tag2) don’t work (that was the solution here
Im trying to search for documents containing two tags (or more). I do not want to see documents that only contain one of them. Where the tag is in the document does not matter, they can be placed inline, or in the front matter.
Thank you. I see this work sometimes. If I have nested tags it sometimes does not work (/#[^\s]*tag1/subtag1/), but I don’t know why. If I turn on “Explain search term” it divides the string on /#.
Is this the only solution? Its super inconvenient to write so much for a simple search with more than one query.
