You can probably use a regex search and replace on the page to remove all markdown links.
For example regex101: Remove Markdown Links
Thanks. I am not into regex, I find it too complex to get a handle on, although I admit it would be a very useful tool to have in my toolbox.
But, if I am not mistaken, there are also different flavors of regex, which complicates it further.
I have used VS Code’s global search & replace on Obsidian successfully for my use cases.
I’m in the same boat. Maybe somebody can chime in or ask for help on discord.
Also, it seems the search/replace feature within a note does not support regex, for that you would need a separate plugin
I got it working.
Install the obsidian-regex-replace plugin.
Run the command “regex find/replace” and find \[([^\[]+)\](\(.*\))
and replace: $1
and it will remove external links in the note
in the note but not in all the notes, which is what the OP was about.
