Situation
Both search and the graph view are empty.
- I’ve tried several different search terms that I know for certain exist (easy words, etc)
- I’ve clicked on the tag pane which opens the search for tags: no result in the search pane (though the tag pane shows the tags and the number of pages)
- case sensitive on/off made no difference
- Explain Search Term toggle shows what is searching for (e.g. “Match tag: #atomic”), but nothing under that (no results)
- Backlink pane: linked mentions work, but unlinked mentioned are always empty, too
Graph is just empty, also after resetting all defaults.
I can easily live without a Graph view, but search is by now critical: I have more than 20 files now I’d really like to know what I could do, is there a search index that can be manually rebuilt?
Any help or pointers are very welcome!
