Obsidian makes it very easy to navigate between notes, but it loses much of its usefulness if it does not maintain its reading position.
A configuration file could be created in the root folder that stores the center line of each open note, updating with the autosave.
It is also important to maintain the position in the transition between editing / reading.
Of course, you should not consider specific links to headers.
