Settings → Files and links: “Use
[[Wikilinks]]” off. -
Create a note
Coloncontaining:## Colon:unspaced ## Colon: spaced [a](#Colon:unspaced) [b](<#Colon: spaced>)Write the two links by hand, not with autocomplete.
In a folder
sub, create a note containing[c](../Colon.md#Colon:unspaced). -
Hover or click each link.
Y. Reproduced in the sandbox vault.
All three reach their heading. Heading links otherwise match : as a space: #Colon unspaced reaches ## Colon:unspaced.
a and b are styled as external links, show no preview, and do nothing when clicked. c reaches the heading. Autocomplete itself writes #Colon%20unspaced, which works, so the problem shows only in links written or copied by hand.
Obsidian version: 1.14.5
Installer version: 1.12.7
Operating system: #1 SMP PREEMPT_DYNAMIC Tue Oct 6 19:13:07 UTC 2026 6.18.54.1-microsoft-standard-WSL2
A possible cause: the link is treated as external when a : comes before any /, as in a URL scheme. The archived Markdown link broken when link to heading (topic 46273) (2022) fits this: […](文本匹配问题.md#Q:%20…) failed where […](./文本匹配问题.md#Q:%20…) worked. Possibly the same root cause for external links: Links including a colon in the domain/path component do not work (topic 8253).
