Right click context menu opens and closes immediately
When writing sometimes I make mistakes and the spell check will underline them, traditionally I would right click on the word once and then select the appropriate corrected word.
On Linux Mint when I right click on a word sometimes the context menu will open and then whatever option is under the cursor will be automatically selected and the menu will close.
This happens some times, others it doesn’t.
It only happens inside obsidian’s text editor, not in the file browser or outside of obsidian.
It doesn’t happen in MacOs with the same plugins activated.
This is also a “new” behavior, few months back this wouldn’t happen.
Check if it’s a mouse thing by testing outside the text-editor.
Settings browsing to see if I was missing something looking for “right click”, “context menu”.
