I often use multiple vertical split editors. This is great for seeing multiple notes at once. As long as you keep the number of editors fixed.
One thing has been driving me nuts: if you ever close an editor or do another vertical split, all of the editors resize, and their scroll positions all change.
Scroll position is also lost if you resize the window.
Scroll position should remain fixed through the split. Ideally the top part of the text should be fixed in place.
