Thank you @faysalforbd ! In understand better : you need to be in reading mode for the audio player to be resized with media-extended plugin (it does not work in Live Preview).
It works well, however if you try smaller size (let’s say 200, which is still quite wide if you want to include in a dataview table), the player is not displayed properly :
Do you have the same behavior ?
