Repeated reindexing of vault
Whenever I start up Obsidian, it re-indexes my main vault. Each time it does this, the message windows says that it will only happen once. With over 40k files in the vault it is a non-trivial exercise and takes time. Why does it keep starting from square one and how do I avoid this?
I did see an old similar bug report from a couple of years ago but no solution.
You didn’t follow the bug report template. Moving to help.
Did you let it finish?
Does the number of notes to index go down over time?
I did allow it to finish, repeatedly (on subsequent days). The number of files did go down as expected and did reach zero. In other words, it is finishing apparently successfully. Everything works fine. It would seem that on completion some internal flag is not being correctly set (just a guess). However you look at it, it appears to be a bug.
This isn’t about whether it is a bug or not. You need to supply enough information either A) to reproduce the bug so it can be fixed, or B) to give us enough information to see what the problem might be to give you suggestions. The templates are there for a good reason.
What OS? What Obsidian version? What plugins? What path is your vault stored in? Are you using cloud syncing tools? etc. Please give more information.
Okay here it is in the bug report format (I hope)
Add the new file structure to the existing vault. This is a small test vault with only about two dozen entries.
Yes I tested it in a new vault.
When Obsidian starts, the re-indexing window appears at the top right. It says that the process will occur once. The re-indexing proceeds, with the record countdown, as expected. Once it completes, the window closes and Obsidian functions normally.
The newly added structure functions correctly.
Every time Obsidian is reloaded, the re-indexing of the vault is repeated, taking the same amount of time and counting down as would be expected. But it repeats on every reload.
The system otherwise functions normally and all references work just fine. If I didn’t know that is shouldn’t repeatedly re-index I might think it was normal.
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: Windows 10 Pro
System: Intel i5 8G Ram 1T SSD (40% full)
Snippets enabled: 1
The file structure being indexed is roughly 40k files. It has been tested and is working elsewhere.
My Vault is available for testing on request.
What does the popup say exactly when you start obsidian?
Okay, so just make me out to be a liar (haha) and add mystery, it magically resolved. I loaded Obsydian again to take a screen shot of the re-indexing window and it did not do it! Several reloads since and nada. I have no idea why, but I have an anecdotal guess. The last time that it re-indexed I left it running for at least a hour after the re-indexing windows countdown showed zero and the window closed. Could it be that it continued to work in the background for some time and actually did complete after some period? That is the only explanation I can think of. Considering it was indexing well over 40k files, it might be plausible…
