If using inner link as heading, then the square brackets are also shown in the outline. I think the square brackets should hidden in the outline.
Is that possible to remove the square brackets in outline when using inner link as heading?
Still very much interested in a native solution! The outline plugin mentioned by @anon63144152 works well but I think it would be great if we wouldnāt need a plugin for that!
Agreed, it is such a basic thing. It is like the Search and Replace feature across all notes that we have to use a plug-in or something VS Code for. These features are no-brainers, and yet ā¦ā¦
Markdown formatting will be stripped beginning with v1.2.3, same goes for publish. Note that this is different from rendering it, so this feature request remains open.
What does that mean in practical terms? What will we notice, and how is it different from rendering?
## My **heading** with a [[wikilink]] and a [markdown link](example.com)
My heading with a wikilink and a markdown link
So, what is the objective of markdown stripping?
Partially address the complains this thread.
I use the Visually Numbered Headings plug-in, which is a very important one for me to navigate long notes.
Will I still be able to use it when markdown stripping is implemented?
I am not familiar with that plugin.
Fair enough.
I am on a Mac. In case v1.2.3 affects the plug-in negatively, is there a way to downgrade back to v1.2.2?
Thanks for jumping in, @obsequious . The page that you link to only lists the installer version, not the Insider versions.
1.2.3 is an Insider version, as is 1.2.2. So, if I would want/need to downgrade from 1.2.3 to 1.2.2, where could I find a copy?
Secondly, do you know where is the downgrade procedure is described? I seem to remember vaguely that it was mentioned once or twice in one of the Discord channels quite a long time ago but I did not pay any attention to it because I did not think I would ever need it
In Discord, ārollback insiderā will trigger Carl to provide brief instructions. I recently posted an expanded version here: Downgrading version on mac - #3 by CawlinTeffid
Many thanks for providing those instructions. I will bookmark the page. Thanks again!
A related issue is having LaTeX in headlines. I was about to raise this issue but then came across Render LaTeX in outline - #2 by robotsheepboy and this thread.
