I work with producers on projects, so I open a note for each project and tag the producer in it with #Producer/(name). Using Dataview I built a table to show all my current projects and sort them by producer.
TABLE
rows.file.link AS "Project"
from #Producer AND -"zArchivedProjects"
FLATTEN file.etags AS Tags
WHERE contains(Tags, "#Producer/")
GROUP BY Tags AS "Producer"
SORT Tags DESC
This is how it looks like:
It works as expected, but I want to try to tweak it even more:
Is there any way to render the tags as text instead of being a clickable tag? I did it using YAML tags, but I want to avoid using YAML.
Dataview is case-sensitive when reading tags: ‘Producer’ tag show up, but not ‘producer’. Notice Elaine is not showing up, because I tagged her as /producer instead of /Producer, although Obsidian adds her to the correct tag group. Is there any way to avoid this?
Thanks!
