Rename field does not scroll into view above keyboard on mobile
Steps to reproduce:
  1. You need to have a bunch of notes (more than 20). They should be in the main vault folder.
  2. Long press one of the notes at the bottom of the list.
  3. Select Rename. (The selected note should be near the bottom of the file list.)
Yes
Expected result:
The note (or folder) being renamed should scroll up and appear above the keyboard.
Environment:
Operating system: Android 14 (Samsung SM-A725F)
WebView version: 144.0.7559.109
Obsidian version: 1.11.7 (287)
API version: v1.11.7
Login status: Not logged in
Language: English
Live preview: On
Base theme: Dark
Community theme: None
Restricted mode: Off
Plugins installed: 5
Plugins enabled: 0
None
Additional information:
This issue does not only affect notes; folders have the same problem.
It happens with bottom notes/folders that have nothing below them. If there are enough notes after the selected item, it scrolls correctly.
Suggestion:
Maybe it could use this pop-up for renaming.
InShot_20260211_134107554
I can repro on iOS:
	Obsidian version: 1.12.1 (291)
	API version: 1.12.1
	Operating system: iOS 26.2.1 (Apple iPhone18,1)
	Catalyst license: supporter
	Base theme: light
thanks
