Remove / Disable Indenation for specific Headers H3 and H4
I want to remove indentation especially for specific Headings i.e. for h3 and h4
  • So basically I create my notes which contains multiple H2 and each H2 has multiple H3’s and H4’s inside it
  • When I fold all headings it closes all Headings, as expected but I want it to only work for H1 and H3 is there any way to disable it for H3 and H$
Current Solution that I use
  • I use Creases Plugin and have set Toggle H3 and H4 shortcut, So when I close all heading + I use the Creases shortcut for toggle H3 and H4
Can someone suggest how to disable indentation only for H3 and H4
