for some reason, I can not find my citations in the remote vault. I don’t know what to do? Any suggestions?
I would start here:
- Run the command “Show debug info” in Obsidian and paste the results here.
- Provide more information about what your problem is. What do you mean by “can not find”, and “the remote vault”? What are you syncing with? You can see the citations on one computer, but not another? What do you mean by “citations”? Is this a plugin, or footnotes, or?
I don’t have a technical background. How do I run the command ‘Show debug info’?
Thanks, Nevine
Ctrl + P → Show debug info
Obsidian version: v1.0.0
Installer version: v0.15.9
Operating system: Windows 10 Home 10.0.22000
Catalyst license: none
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Citations v0.4.5
community plug-in sync is enabled.
