Relabeling note box on the fly?
There’s probably an easy answer to this, but searching is just giving me a bunch of information about managing notes – as in, the main substantive things in Obsidian – and that’s not what I’m looking for. But I don’t know what else to call it.
I’m wondering if there’s an easy way to rename a note box on the fly. The thing you create with this:
[!note]
Is there something I can enter there that will change the label that displays, from “note” to something else? Kind of like how you can change the display size of an image or the display text of a link? Or is this only something that can be changed universally in the template code?
See Callouts - Obsidian Help
If I understood you right, just right-click on your callout and change it to another type. That’s pretty quick.
[!note] Your title
