sergy
#1
Sample text
Ukraine is a country in Eastern Europe. It is the second [[largest country in Europe]] after Russia.
In the global search for obsidian, I want to find [[largest country in Europe]] for any occurrence.
So far I’ve gotten to /[.*?searching-text]]/ , but that doesn’t work correctly.
sergy
#2
If anyone needs it, it worked for me /\[\[(.*?searching-text.*?)\]\]/
Angel
#3
Isn’t it easier just to search for:
"[[largest country in Europe]]"
What is the advantage of using regex in this case?
Angel
sergy
#4
I can’t search “[[country in Europe]]” or “[[Europe]]” in sample text. I want to be able to search on an incomplete match.
sergy
#5
If you know how to do this without regular expressions, I will be grateful.
Angel
#6
Apologies. I thought you wanted to search for whole expressions, not partial ones. I misunderstood.
Sadly, I don’t know how to do what you want with regex. Hope someone else can help.
Angel
system
closed
#7
