The Start Here document says:
By the way, you can feel free to edit these help docs, but when you click Settings => Help => Read Help again, they will be overwritten. So, don’t put anything in them you want to keep.
However, when I click the Settings button I don’t see a Help section. The closest thing I see is “Help” on the side and Settings => About => Obsidian help [Open], neither of which seems to regenerate the help text. How do I regenerate the help text after modifying it?
It will regenerate once we push a new version of the docs. You can manually regenerate it by deleting the relative directory.
You can also access the latest help docs through the publish website -> https://publish.obsidian.md/help/
Which relative directory?
