Building notes from blocks of other notes, that still connect to all the other notes in the graph
For example:
Say I create Note B about a movie, with each scene under different headings. This makes it easy to ![[embed]] each scene into notes about different themes, such as into Note A.
But if I go to look at the graph, the Note A is not linked to any other notes, despite it containing embedded blocks of Note B that does [[link]] to other notes
Allow backlinks that are inside embedded notes (Note B#Heading 1) to be considered part of the backlinks of the note itself (Note A). This would now behave as a subset and allow notes to be built from other notes meaningfully.
Not suggesting this for simple [[backlinks]] themselves, but for ![[embeds]] where you can now see the written backlink inside the main note when in Preview. That suggests to me that there is a sufficient reason for that backlink to be treated as part of the main note, as it is obviously relevant.
Maybe a separate section for backlinks within embeds, that still links on the graph. Or maybe an option to set this on or off depending on your preference?
Hope this makes sense. Someone had the same problem they posted in Help, to no response, if this makes it clearer: Backlinks inside embedded blocks.
