Rearrange right sidebar
Hi, I’ve messed up my right sidebar. I thought It would be easy to re-arrange the items by dragging, but it does not seem to work?
Left mouseclick and hold on one of the content boxes on the panel dus not give me the possibillity to drag. Rightclick also doesn’t give me a context menu to to reset the layout?
So is there a possibillity to either reset the layout on the right menu to default, so I can start to rearrange it again or how can I “drag and drop” the content of the right sidebar?
I am using Windows 11 and Obsidian 1.9.14
In the mean time, I have created a new vault, copied all my files to that one and recreated the configuration as well as I could. Then setup the sidebar as I wanted it to and don’t touch it. It’s inconvenient, but worked.
Okay, aparently on Linux, I can drag-drop the icons of an object. Not sure what happened on Windows. I removed the old vault, am not trying again.
It seems you’ve sorted it out, but if your workspace gets messed up in the future, you can always move or rename the VAULT/.obsidian/workspace.json file and close-open the vault. The vault will reopen with the default layout, including the sidebars.
