Paste this into a note and open Reading view:
a * foo bar*
a ** b ** c
foo_bar_
__foo, __bar__, baz__
Yes (reproduced in the sandbox vault, no community plugins).
As the CommonMark spec (0.31.2) renders them:
| Markdown | CommonMark HTML | Spec example |
a * foo bar* |
a * foo bar* (a * followed by a space cannot open emphasis) |
351 |
a ** b ** c |
a ** b ** c |
same rule |
foo_bar_ |
foo_bar_ (a _ inside a word neither opens nor closes) |
360 |
__foo, __bar__, baz__ |
<strong>foo, <strong>bar</strong>, baz</strong> |
389 |
| Markdown | Reading view HTML |
a * foo bar* |
a <em> foo bar</em> |
a ** b ** c |
a <strong> b </strong> c |
foo_bar_ |
foo<em>bar</em> |
<strong>foo, </strong>bar<strong>, baz</strong> |
Reading view pairs * and _ runs first come first served, without CommonMark’s left- and right-flanking checks, its rule for _ inside words, or its nesting rules. Words in other scripts are affected the same way (пристаням_стремятся_ gives пристаням<em>стремятся</em>, example 362).
Obsidian version: 1.14.5
Installer version: 1.14.4
Operating system: Windows 11 Pro 10.0.26300
Sandbox vault, no community plugins, default theme and settings.
Measured on the CommonMark 0.31.2 spec examples in Reading view (default settings). Other examples with the same cause: 352-354, 358-359, 366, 368-369, 371, 373, 375, 379-380, 383-388, 391-392, 397-398, 400-402, 407-409, 413-418, 425-427, 432, 437, 439, 443-447, 449, 451, 455-459, 464-468, 470-472.
Related: Commonmark-compliance: Reader should NOT parse intra word underscore (CJK and Cyrillic) covers the _-inside-a-word part for CJK and Cyrillic text. This report adds the Latin cases, the spaces-inside-delimiters cases and nesting.
foo_bar_baz (an _ pair fully inside a word) is left alone, which is right, but __a__b still gives <strong>a</strong>b.
