Open the window in full-screen view, switch to reader view.
Update the file from outside obsidian or this particular window.
After some time, somewhat randomly, the view hangs, and then it stops reflecting the actual changes even if you switch back and forth to Live Preview, editing the file from the very same window.
Reader view is updated after every file change that got persisted on the disk, either by obsidian or by an external process.
The view hangs and no changes happen.
- Operating system: macOS 12.5.1
- Debug info: I did not copy it, and this bug is a bit of a heisen, but I was able to reproduce it in 0.16.2, 0.16.3 (+ with the default theme and all community plugins disabled)
