There are two similar situations:
  • I’m typing, and just typed a word, and realized I should have linked it
  • I’m reviewing a previously typed note, and I find a word that should have been linked
Is there an easy way to turn a word into a link without typing [[ ]] ?
If not, I will probably submit a feature request. I would love to double-click a word to make it a link or a right-click shortcut.
If you select text and tap [, it will surround the selected text with []. Press that twice and you’re done!
This worked!
I think I’m still going to suggest a feature where you can double-click on a word to make that happen.
