Questions on properties
I’ve been using a few fields in the front matter that I’m now having trouble with because of properties.
  • the plugin natural language dates no longer works for adding a date property :frowning: how can I fix this?
  • I can’t have multiple options for a front matter property e.g. I had a field called “email” where I could have multiple emails stored…
email:
- email1
- email2
Now it won’t let me enter multiple emails, and if I do have an old note with multiple emails under the “Email” front matter it tells me the type is wrong.
  • It’s probably better to make an issue on the github page for the NLD plugin, you are more likely to get support there.
  • You have to click the icon next to ‘Email’ and change the property type to List instead of Text.
