The regulars are all set, and the CurlyCloze button is also turned on
After input according to the format, the ID number will be displayed, #flashcard is completely valid, but the conversion of fill-in-the-blank questions can only follow the Anki syntax format of {{}}
, once the format of the plug-in is used, it cannot be converted, the card shows that the blank cannot be found, and the card is still {} instead of {{}}
This is the regex copied from github: ((?:.+\n)(?:.{.)(?:\n(?:^.{1,3}$|^.{4}(?<! <!–).))*)
Can anyone help me with this, it’s been bothering me all day.
