Questions about otter.ai and iframe
Embed an otter.ai transcript in an obsidian document, navigate between tabs using the keyboard, and control the otter.ai web app using the keyboard.
I tried using the iFrame instructions in help.obsidian.ai and the resulting document was a tiny little square. It didn’t show the transcript, just the audio playback controls.
I then used the Custom Frames plugin
That works pretty well, but I can’t use the keyboard to navigate between tabs, and I can’t use the keyboard controls for the Obsidian Web app.
Has anyone found a usable way to embed an individual otter.ai transcript in an obsidian document and use the keyboard for navigation between tabs, and to control the app?
Thanks!
