Hi!
After looking around for a good tool for a rather long time I’ve now started migrating everything to Obsidian/Markdown. I like it.
A few questions:
1 Can I follow links using just the keyboard when writing? Now I switch to the mouse, takes extra seconds and movement of my right hand.
2 I can create new notes by clicking the links, but this seems to fail if folders would have to be created, is this a known bug? I like to structure my information in a folder hierarchy.
3 Internal quick links, if I have a topic # Foo in a document, in orgmode I could directly link to that using {{Foo}} instead of the full {{filename.org::Foo}}, is there a similar way or do I always have to write full links?
Quick response on:
Yes, alt+enter for me on a Mac. Check settings → hotkeys!
Ah, thanks!
