Question about my archived theme entries (high volume submissions)
Hi! I’m Nikita Borozdov (community directory: borozdov, GitHub org: borozdov-obsidian-themes).
Today 70 of my theme entries (“Borozdov Agenda”, “Borozdov Gallery”, etc.) were archived with the reason “High volume theme submissions. Please use the Style Settings plugin instead.” They also show “Name not allowed in the directory”.
Sorry for the flood. I didn’t know there was a limit on how many themes one author can list. Each theme is a separate design (its own palette, layout and in some cases an embedded OFL font), not a recolor of one base, but I understand why 80 entries is too many.
I’d like to fix this the way you prefer:
  1. How many separate theme entries per author is acceptable?
  2. Would it be OK to keep a small set of the most distinct themes as separate entries and merge the rest into one theme with Style Settings variants?
  3. Should I archive the 10 entries I submitted today (Keepsake, Kernel, Kite, Marker, Masthead, Memoir, Nebula, Passport, Pebble, Phosphor) myself?
  4. Is the “Borozdov [Name]” naming a problem in itself, or is that notice only how the archived entries are hidden?
I’ve stopped all new submissions until I hear back. Thanks!
Hey, thanks for reaching out.
Your themes were archived because the number of themes you posted in roughly a week time made up around ten percent of the entire theme catalogue. While we don’t enforce hard limits on the number of theme/plugin entries per author, the volume, rate of posting new entries, and relatively small differences between each theme, let us to put a blocker on your submissions.
Looking at the description of your GitHub organization, it is clarified that there are roughly 5 “distinct” themes, in addition to the three featured themes:
Every other theme, grouped the way they were designed — pick a mood, not a name.
  • Warm paper & editorial — Тёплая бумага и редакционный стиль, 28 themes (Borozdov Ember, Borozdov Sienna ,Borozdov Eggshell, Borozdov Whisper, Borozdov Folio, Borozdov Clay, Borozdov Scholar, Borozdov Ash, Borozdov Colophon, Borozdov Tally, orozdov Bulletin, Borozdov Quarto, Borozdov Essay, Borozdov Brief, Borozdov Broadside, Borozdov Gazette, Borozdov Salon, Borozdov Terracotta, Borozdov Kernel, Borozdov Manuscript, Borozdov Ribbon, Borozdov Pebble, Borozdov Cabin, Borozdov Primer, Borozdov Memoir, Borozdov Masthead, Borozdov Tacet, Borozdov Monograph)
  • Notebooks & playful color — Блокноты и игривые цвета, 20 themes (Borozdov Recess, Borozdov Doodle, Borozdov Swatch, Borozdov Cirrus, Borozdov Pop, Borozdov Agenda, Borozdov Cork, Borozdov Clipboard, Borozdov Keepsake, Borozdov Copybook, Borozdov Sonnet, Borozdov Flashcard, Borozdov Palette, Borozdov Almanac, Borozdov Crayon, Borozdov Marker, Borozdov Passport, Borozdov Hush, Borozdov Hive, Borozdov Whiteboard)
  • Botanical — Ботаника и природа, 14 themes (Borozdov Terrarium, Borozdov Herbarium, Borozdov Trellis, Borozdov Understory, Borozdov Voltage, Borozdov Spruce, Borozdov Canopy, Borozdov Tonic, Borozdov Apothecary, Borozdov Cultivar, Borozdov Kite, Borozdov Atelier, Borozdov Riverstone, Borozdov Glacier)
  • Cool light minimalism — Холодный светлый минимализм, 21 themes (Borozdov Compositor, Borozdov Beaker, Borozdov Ledger, Borozdov Wire, Borozdov Clinic, Borozdov Tracing, Borozdov Easel, Borozdov Marble, Borozdov Tessera, Borozdov Keynote, Borozdov Cobalt, Borozdov Flint, Borozdov Porcelain, Borozdov Alpine, Borozdov Archive, Borozdov Utility, Borozdov Grayscale, Borozdov Specimen, Borozdov Vial, Borozdov Pixel, Borozdov Blueline)
  • Dark consoles & midnight — Тёмные консоли и полночь, 14 themes (Borozdov Signal, Borozdov Beacon, Borozdov Neon, Borozdov Phosphor, Borozdov Cockpit, Borozdov Cathode, Borozdov Deck, Borozdov Stage, Borozdov Claret, Borozdov Ticker, Borozdov Forge, Borozdov Nebula, Borozdov Console, Borozdov Velvet)
These groupings read as variations of a singular theme each. As such, the recommendation was given to use the Style Settings plugin. If you were to combine the five groups into five themes, that would be perfectly acceptable (or eight, if you want to keep the three featured theme separate.)
The block has been lifted, so you should be able to unarchive the individual themes you want to roll these groups into.
Please let us know if you require assistance with the conversion, or if you have further questions.
Thank you for the clear explanation and for lifting the block. Done as you suggested: the five mood groups are now five themes, each carrying the rest of its group as Style Settings variants (Style Settings → Borozdov [Name] → Variant), released as 1.1.0:
  • Borozdov Ember: warm paper & editorial (27 variants)
  • Borozdov Palette: notebooks & playful color (19)
  • Borozdov Trellis: botanical (13)
  • Borozdov Utility: cool light minimalism (20)
  • Borozdov Console: dark consoles & midnight (13)
Together with Borozdov, Gallery and Sprout that makes eight entries. I’m unarchiving only those (the portal’s rate limit spreads it over a few hours); everything else stays archived, and I won’t submit new themes. The standalone repositories stay on GitHub. Thanks again!
