Hi.
About dataview, for now you can’t query headers/section (only possible for tasks queries).
But you can use inline fields using the format key:: value. For example:
Project ABC
#project
Description
description:: Lorem ipsum dolor sit amet, consectetur adipiscing elit. Integer aliquet eu nibh sed pharetra. Praesent sit amet magna vel lacus condimentum finibus id ac quam. Cras eu eros posuere, molestie lacus at, laoreet purus.
With full inline fields the value need to be in same line. If you want to break line (or write another description in other place, you can add multiple description:: blabla (as result you get a list of description in your note.
With this method you can use this simple dataview query:
```dataview
TABLE description
FROM #project
SORT file.name ASC
