For Linux, we only accept bug reports that are reproducible with our AppImage or Snap package under Gnome or KDE.
I made a base with the filter if tag is move and property cost (number) is not empty. If I add a new note from there and fill the cost field with a number I still get the exclamation point with the hover message “type mismatch expected Number”. The number is on the left side and does not count in the summ.
If I click the exclamation it will work.
Obsidian version: 1.12.4
Installer version: 1.12.4
Operating system: Windows 11 Pro for Workstations 10.0.26200
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
Workaround
In the new-note popup, click the orange caution triangle to update to number format.
Or, after entering a value and saving it (by clicking elsewhere in the popup), delete the value and save it (again by clicking elsewhere in the popup). Obsidian instantly updates the property type even in the popup.
