And that’s the code for it:
const rootKey = "__root__";
if (input && dv) {
const properties = dv.el("div", "", { cls: "note-properties", attr: { id: "properties-container" } });
// Set up a tree-like dict of all the directory {path : ul element} mappings
let listTree = {};
let header = "Properties";
let obj = {};
const frontmatter = dv.current().file.frontmatter
if (Object.keys(input).length === 0 && input.constructor === Object && frontmatter.hasOwnProperty("note type")) {
const note_type = frontmatter["note type"];
switch (note_type) {
case "electrochemical cell":
header = "Cell Properties";
obj = frontmatter["cell"];
break;
case "device":
header = "Device Properties";
obj = frontmatter["device"];
break;
case "instrument":
header = "Instrument Properties";
obj = frontmatter["instrument"];
break;
case "chemical":
header = "Chemical Properties";
obj = frontmatter["chemical"];
break;
case "electrode":
header = "Electrode Properties";
obj = frontmatter["electrode"];
break;
case "reference electrode":
header = "Reference Electrode Properties";
break;
case "process":
header = "Process Properties";
obj = frontmatter["process"];
break;
case "sample":
header = "Sample Properties";
obj = frontmatter["sample"];
break;
case "analysis":
header = "Analysis Properties";
obj = frontmatter["analysis"];
break;
case "lab":
header = "Lab Properties";
obj = frontmatter["lab"];
break;
default:
obj = frontmatter;
else {
let key = "";
// check if input has property "key"
if (input.hasOwnProperty("key")) {
obj = frontmatter[input.key];
key = input.key;
else {
obj = frontmatter;
if (input.hasOwnProperty("header")) {
header = input.header;
else {
// if key is not empty, capitalize the first letter
if (key !== "") {
key = key.charAt(0).toUpperCase() + key.slice(1);
header = `${key} Properties`;
dv.header(2, header, { container: properties });
listTree[rootKey] = dv.el("ul", "", { container: properties });
yaml_object_to_list(obj, listTree, 0, "");
function yaml_object_to_list(obj, listTree, level, parent) {
if (parent === "") {
parent = rootKey;
const objkeys = Object.keys(obj);
objkeys.forEach(okey => {
if (obj[okey] instanceof Object) {
if (obj[okey] instanceof Array) {
const parentEl = listTree[parent];
// check if the array contains an object
if (obj[okey].length > 0 && obj[okey].some((e) => e instanceof Object) ) {
const listEl = dv.el("li", "", { container: parentEl });
dv.el("div", okey, { container: listEl, cls: "property-object" });
listTree[okey] = dv.el("ul", "", { container: parentEl });
obj[okey].forEach(entry => {
if (entry instanceof Object) {
yaml_object_to_list(entry, listTree, level + 1, okey)
else {
dv.el("li", `${entry}`, { container: parentEl });
else {
const data_type = "list"
dv.el("div", okey, { container: listEl, cls: "property-key", attr: { "data-type": data_type } });
obj[okey].forEach(element => {
const data_type = get_data_type(okey, obj[okey]);
dv.el("div", element, { container: listEl, cls: "property-array-value", attr: { "data-type": data_type } });
// console.log(JSON.stringify(obj[okey]))
} else {
yaml_object_to_list(obj[okey], listTree, level + 1, okey)
} else {
// determine data type of obj[okey]
dv.el("div", obj[okey], { container: listEl, cls: "property-value", attr: { "data-type": data_type } });
function get_data_type(key, value) {
let data_type = "string";
if (typeof value === "number") {
data_type = "number";
else if (typeof value === "boolean") {
data_type = "boolean";
else if (typeof value === "object") {
data_type = "object";
else {
switch (key.toLowerCase()) {
case "date":
data_type = "date";
break;
case "time":
data_type = "time";
break;
case "link":
data_type = "link";
break;
default:
return data_type;
