Properties: How to hide only fields that have no values in YAML
As an example I use this YAML in in Obsidian v.1.4.5:
aliases:
  - ABC
  - DEF
tags:
  - GHI
  - JKL
KA05: ""
case2: "-"
none: No value
whatever: "xyz abc"
nothingatall:
How can I hide the last 5 fields in view mode, depending only on their values but independly of the fields?
This does not work:
.metadata-property[data-property-value=""],
.metadata-property[data-property-value="-"],
.metadata-property[data-property-value="No value"],
.metadata-property[data-property-value="xyz abc"],
.metadata-property[data-property-value=''] {
    display: none;
Maybe try .metadata-property:has([placeholder="No value"])
Thanks, but that doesn’t work either.
