Properties blocks locating search result when window is resized
  1. resize obsidian window to either half left/right
  2. search a keyword
  3. click on a keyword where a note has a long Properties section
  4. see Error: the search result is not located until scroll down a little bit. In “test2” note, there is no Properties and the search result is located immediately. Whereas in “test” note where properties section is long, it blocks the search result.
20260912_230152
Did you read and follow the Troubleshooting Guide ? [Yes/No]
Yes
The search result should be located immediately
The search result is not located immediately and blocked by Properties view
Obsidian version: 1.14.1
Installer version: 1.12.7
Operating system: Darwin Kernel Version 25.6.0: Fri Jul 31 19:11:49 PDT 2026; root:xnu-12377.161.14~5/RELEASE_X86_64 25.6.0
Catalyst license: supporter
Insider build toggle: on
Snippets enabled: 12
