Properties are not added from template when inserting into a note in Canvas
  1. Create a template note with properties in it like:
foo: bar
Lorem Ipsum
  1. Create or open a canvas
  2. Add a new blank note to the canvas
  3. Insert the template from the test template note above. Properties are not added
Y
Properties from template note added to the note in the canvas
Properties are not added, all other text from template added correctly
Obsidian version: v1.5.3
Installer version: v1.4.16
Catalyst license: none
Works as expected if the whole text from the template note is copied in source mode and then pasted into the note
thank you
