You can create a note with absolute links, such as
[[DarkSoulTemplate\Characters]]
[[DarkSoulTemplate\Settings]]
[[DarkSoulTemplate\Graphic]]
and then rename the folder to, for example, DarkSoul1
Absolute references will create a folder with the specified name in addition to the note.
If you need a similar template for each note use the Templates or Templater plugin.
Now I’m in DS1 folder.
When I’m typing [[Set…]] editor propse me “Settings” from DS1 and “Settings” from DS2.
Is there any way to limit editor propsitions only to folder where I’m actually writing?
It’ could be messy with 100 project folders.
Absolute links works great with default setting.
If I change my settings “Folder to create new notes in” to “inBox” then after clicking [[DarkSoulTemplate\Characters]] it create (folder + note) [[DarkSoulTemplate\Characters]] inside “inBox” folder.
The same with [[MainVault\DarkSoulTemplate\Characters]].
