Problems with pictures
various problems with images
The latest version of Obsidian gives me headaches:
  1. Pictures, when clicked, open always in fullscreen. I don’t want this by default. Most of the time, I’m just checking and need a bigger preview. I need no presentation, how to deactivate this?
  2. Rendered Image links are now locked in our active note. My vault is local only, how to deactivate this ?
I don’t see any changes regarding rendering of images. (But I did see changes when 1.13+ public came out.)
The only CSS change I am seeing so far since the latest ver 1.14.4 (in any theme, including the Default theme) is that plugin icons in sidebars are a bit more squeezed than before.
Thanks, for the hint. Need to check if flatpaks updated already for my OS.
Yes, I’m on v13.7 and see how external tools can’t rename anymore file links in active notes, for instance sed.
But images open still in fullscreen on v14, right?
Clicking on images open images the same size as they are in Live Preview or Reading mode. I have another plugin that I use for images which I have disabled now for testing this out.
Yes images open the same size: previously css allowed me to scale images to fill the screen on the y axis for portrait format pictures and to fill the x axis for landscape format pictures.
Now images stay same size and get a ton of black bg padding in fullscreen.
I don’t need:
  • the black background
  • forced same-size ratio
This is now the default mode in Obsidian, to verify deactivate plugins, css and themes.
