How do I embed a local table or an online table in Obsidian?
Because the table is large, it doesn’t display well in the table syntax of markdown.
So I don’t think about using the Markdown syntax.
If you don’t need LaTex equations, I think the HTML table works. You might be able to embed images into the table with the newest version (haven’t test that yet. I guess only the absolute directory works for now.)
