Open note
Activate dictation
Dictate some stuff, then say “new line” or “new paragraph”
Resume dictating.
Deactivate dictation.
Did you follow the troubleshooting guide? [Y/N]Y
A line feed where I said “new line”, and two line feeds (a blank line) where I said “new paragraph”.
Line feeds and Blank lines shows while dictation activated, but ≈ 75% of the time they vanish once dictation is turned off. I keep having to re-edit my notes to insert the missing line feeds.
Obsidian version: 1.12.7 (303)
API version: 1.12.7
Operating system: iOS 18.6.2 (Apple iPad15,7)
Plugins installed: 3
Plugins enabled: 0
Changed from minimal to default themes, deactivated all css snippets and plugins - still there. Tested dictation in Pages and iawriter - “newline” and “new paragraph” generated one LF and two LFs, respectively, with no errors. Tried “strict linefeed” option in obsidian settings - it eliminated single linefeeds from reading view, but did not change the reliability of the dictation.
