Problems with Dataview Plugin Results being cut off by window size
Hello, all. I am havin an issue that when I query file.name with the dataview plugin, the names of my files are being cutoff by the left side of the code block. I am not sure if this is a known issue or if my setting are incorrect. Any assistance would be greatly appreciated. Below, please see the error that I am talking about as well as my query:
Moved to help
It’s most likely your setting, and/or theme. It’s not a common issue.
What setting would that be?
It was my theme Blue Topaz.
So, for anybody having this same issue, if your theme is not the default, switch to the default and see if that fixes it.
