Problems to refer to a specific place in a longer text within a note
I use osidian for historical commentary, whereby I have sources in Latin that are translated into German and which I comment on. To do this, I use links by defining the passage I want to comment on with simple square brackets and placing the comment directly after it in round brackets, like this (comm_Enn_5a). I often have to refer from one text to another, for which I link the text I want to refer to with two square brackets. Since I usually want to refer to a specific passage, I put a hash and a caret after the title of the text so that a window with the desired text opens, in which I can then scroll down. It then looks like this [[Enn_Lib#^]]. This works with all texts except one that is very long and also colour-coded with Markdown, and whose paragraphs have also been assigned Markdown tags and ‘Introduction’. With this long text, I can only scroll down to about 2/3, then it stops.
I would like to refer to a place in a text and to scroll there for marking, what is not possible because I’m not able to scroll there because the lower part of the text is not displayed.
With this long text, I can only scroll down to about 2/3 of the way, then it stops. I got a tip via AI (Blackbox AI) to structure the text using numbers. But that didn’t help much. Do you have any idea how I can leave the text as a whole and scroll to the end when I want to scroll to a specific place in it?
I have to say that I have no knowledge at all in informational questions but willing to learn because obsidian is an ideal tool for my research purposes.
